newB from NW Iowa
Discussion in '1947-1954' started by 48long3804, Feb 5, 2009.
  1. vwnate1
    Vacuum Wipers
    I hope you've recently adjusted your valves and have the iginition timing correctly set ! .
    Remember : they're supposed to stop when you tromp the throttle there's an easy fix for this .
  2. ccharr
    They were really not much use today :eek:, going to have to fix them some how before to long.
  3. 48long3804
    48long3804 Member
    North of Aliendorf, IA
    Thanks Charles. I really like your truck too and all 9' of that BOX!:D:eek:
    Vacuum Wipers = EASY PEASY !
    1. Send the motor off to Ficken Wiper Service in New York .
    2. install a vacuum resivoir up under the dashboard\
    3. install a one way vacuum valve in the primary vacuum line from the intake manifold
    4. watch how perfectly your vauum wipers work ascending hills and leaving dead stops .
