Can't figure it out
Discussion in '1947-1954' started by mobileortho, Feb 16, 2009.
  1. mobileortho
    mobileortho Member
    Hampton, VA
    I have an American Autowire harness that was not at all complicated to install but I have a problem. With the head lights on the front turn signal lights wont work. I've double checked the grounds, checked & rechecked every possible connection but I cannot seem to find the source of the problem. Any suggestions?
    Baby Steps
    Use the test light to ascertain f there's power to the flasher can , then follow the current path downstream and see if there's flashing current leaving the switch etc. , etc. until you find the " open " in the T. Sig. circuit...
  3. Bill Hanlon
    Fredericksburg TX
    What kind of turn signals are installed on your truck?
  4. mobileortho
    mobileortho Member
    Hampton, VA
    The turn signals are the upgraded with the dual contacts so they double as turn signals and park lamps.
  5. Bill Hanlon
    Fredericksburg TX
    And what do you use for a turn signal switch?
  6. mobileortho
    mobileortho Member
    Hampton, VA
    I have a column from what I believe is a late seventies or early eighties chevy pickup.
  7. Bill Hanlon
    Fredericksburg TX
    Well, you just lost me. I know what the connections to a TF turnsignal switch is like, be it 3 or 6 wire, but I know nada about the one you have.
    Combined turn & brake light back then , should be a 6 wire ....
  9. triley
    triley Member
    Ramer, TN
    should go from fuse to flasher to make it hot then from flasher to steering column connector(purple wire on chevy) Then chevy is light blue-LF turn, blue-RF turn, yellow-LR turn, green-RR turn..
    ________
    Redhead live
  10. Bill Hanlon
    Fredericksburg TX
    Assuming rear turn signals share a filament in the buld with rear brake lights, that would only leave out one wire, from the brake light switch to the column. Shouldn't have anything to do with the front turn signals, but just for future reference what color would it be?
  11. ss563
    ss563 Member
    Oregon City, OR
    Wiring Problem
    If you go to Painless Wiring site they have wiring manuals listed for GM columns with all of the wire colors.
  12. triley
    triley Member
    Ramer, TN
  13. mobileortho
    mobileortho Member
    Hampton, VA
    I've also noticed that the rear left tail light bulb keep blowing out. Not sure if the two are related.
  14. triley
    triley Member
    Ramer, TN
    well, i stripped a wiring harness out of a 84 chevy pickup and sit down with a meter and traced every wire....cause i just wanted the tl,bl,ts,horn,lights,cig etc.... so im mating a 84 chevy harness with a 00 vortec lsx computer and harness..but i made me a diagram and mostly all the years close to 84 would be similar....it helped me out a lot...its too big to upload but i can email it if anybody wants to c it....
    ________
    Honda cbr600f4
