Front leaf spring question
Discussion in '1947-1954' started by breezy, Mar 1, 2009.
  1. breezy
    breezy Member
    Monett Mo.
    With all 8 springs in the truck and the load of the truck on them they are practically flat across. I thought they should have some bow to them. What happens when you take leaves out for lowering?? will they bow toward the frame?? And is this good on the springs?? I would not think a spring should bow the oppisite way. Would the stress cause them to break??
    Springs
    As springs wear , they get flatter .
    or , if you got ripped off for cheapo new or rebuilt springs .
    it's unlikely they'll break but you may feel bottoming out a lot when the truck is loaded .
  3. breezy
    breezy Member
    Monett Mo.
    Thanks nate. I'll just be hauling a lawn chair more than likely.
