MY dad has a 61 Apache 10 with an old original rearend. He was wandering if there was a rearend that would bolt to his control arms. I know some of the midsize cars like 79-82 Lemans has a control arm on it, as some Olds do as well. Will that type of rearend bolt to the control arms of a 61. My Dad is missing the front part of the rearend, that the drive-shaft bolts to, as well as the drive shaft itself, or would it be easier put a 63-66 rearend in it. The truck is a short bed and seems to be a little harder to find a driveshaft for. -Russ-
Russ- I own both a 60 & 61 Apache 10 and swapped out rear end from a 68 long wheel base pickup. Look for one with a 350 if at all possible. Line up both rear ends together, take some good measurements, and take the new rear end to a machine shop and have the mounting brackets shaved off, moved and rewelded to line up with your 61's control arms. It costed about $95.00 and I've ran the same rear end for the past 8 years...I'm not sure of one that will bolt right up...hope this helps. verdell
Appreciate the reply, Its got to be a lot easier to get one from a 68 than to find a 61, there just not around where I live, unless there already fixed up. will print the info for my dad, thanks you much -Russ-
Hey how's it going? I have rear end parts for 60-66 chevy/gmc trucks. I also have two drive shafts for 60-66 short bed chevys. If you are interested in any thing i have, e-mail me at: superman0421@hotmail.com My name is Chris Peterson, and am located in Fairbanks, Alaska.
If you still need one. I have a rearend and shortbed driveshaft. let me know you can reach me at antoniopasillo@hotmail.com >MY dad has a 61 Apache >10 with an old original >rearend. He was wandering if >there was a rearend that >would bolt to his control >arms. I know some >of the midsize cars like >79-82 Lemans has a control >arm on it, as some >Olds do as well. Will >that type of rearend bolt >to the control arms of >a 61. My Dad >is missing the front part >of the rearend, that the >drive-shaft bolts to, as well >as the drive shaft itself, >or would it be easier >put a 63-66 rearend in >it. The truck is >a short bed and seems >to be a little harder >to find a driveshaft for. > -Russ-
