window switch Question
Discussion in '1973-1987' started by jonesda123, Feb 24, 2009.
  1. jonesda123
    jonesda123 Member
    Why is the 78 thru 81 master switch so high compared to the the 82 thru 87 whats the difference because i needed one for my 81 silverado when i checked on price i was floored by the price difference !!!!
  2. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    The newer switches are made or Plastic / The older ones are made of white steel (pot metal)
  3. jonesda123
    jonesda123 Member
    But can the 82 thru 87 work on a 81 ???
  4. jonesda123
    jonesda123 Member
    so does any chevy guys know the answer to this one????????
  5. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    Been awhile since I've seen a '78-'81 truck w/ pw in the salvage yard and they were basically the same, but I think they had a slightly different style connector. If you have an older switch you can take it to the parts store to compare it to the newer ones (found in the Help! parts section).
