Guages
Discussion in '1960-1966' started by jsmith, Mar 19, 2009.
  1. jsmith
    jsmith Member
    Can anyone help me find a place that sells individual gauges for my 63? I need a new water temp. gauge. Thanks.
  2. dvalentine
    dvalentine Charter Member
    Sacramento
    I can't help there... May need to look for guage clusters on e-Bay/craigslist..
    Are you positive it's the gauge and not the sender ???
    dv
  3. jsmith
    jsmith Member
    Yes, the sender and wire are new
  4. dvalentine
    Sacramento
    Is it the "correct" sender? Where did you get the sender ? It may not work with older guages if it's a generic sending unit.
    Much like the older senders will not work correctly with newer aftermarket gauges...
  5. jsmith
    jsmith Member
    I bought the sender at advanced auto parts. It matches the plug that runs to the gauge, so I assume it is the right one. I guess that is what I get for assuming.
