I have a 1959 3200 that seems to have a drastic lighting problem. I started out with a generator problem. I have rebuilt the generator and it and the voltage regulator test out OK. However, I now do not have any lights at all, no tail lights, no brake lights, and no headlights. Is there any documentation of quick checks that I can perform to try to pinpoint my problem.
Sounds like you blew the fuse on the headlight switch, thats where I would start trouble shooting anyway. Remove the switch from under the dash so you can see what your doing, and with a test light start checking for voltage. Chris
