New winshield leaks ??
Discussion in '1947-1954' started by breezy, Apr 12, 2009.
  1. breezy
    breezy Member
    Monett Mo.
    So I got a truck with a new windshield and new rubber,everything. IT LEAKS. How do I go about fixing this??
  2. Tailgater
    Tailgater Member
    Greene County, TN
    I took a putty knife to create a valley between the glass and the rubber, moved the knife along carefully while squeezing a bead of black RTV in the valley. I had to put quite a bit in the corners cause they "pooched" out some. I think that is what the shop manual said to do too.
    Gater
  3. breezy
    breezy Member
    Monett Mo.
    Silicone is a bad thing for metal.Acids will cause rusting. I'm going to try some 3m bedding glaze, or try putting some butyl tape behind the rubber.
  4. Tailgater
    Tailgater Member
    Greene County, TN
    I must have misunderstood. Where I put the RTV doesn't come in contact with metal. It goes between glass and rubber. Let us know how it goes and where you put it.
    Gater
    Winshield Leaks & Cures
    You'll need a caulking gun and a brandy new tube of 3M windshield sealer , slash cut the tip to a tiny hole , like 3/16" , make SURE there's not one drop of water in there anywhere and first do the glass to rubber re-seal as Gater said , then do the same thing under the rubber to body lip , don't be shy about shooting in a lot of sealant , when you're finished you can wipe off any excess that mushes out .
    Harbor Freight sells a cheap , nifty hard nylon tool that'll lift the rubber and not scratch either glass nor paint...
  6. breezy
    breezy Member
    Monett Mo.
    Thanks Nate I got some 3m product today.Just waiting on some dry weather.What I came up with is basically butyl in a tube.
    I Hope
    You got the correct 3M windshield stuff as it stays highly flexible for many years , important in the long run .
