5 lug or 6 lug?
Discussion in '1947-1954' started by hardcrab, Apr 13, 2009.
  1. hardcrab
    hardcrab Member
    Northern Neck of VA
    Hey gang,
    I got a 1/2 ton axle to put on my '50 3600 so I can upgrade the front brakes. I was going to just use the bendix brakes that are on the axle, but after taking them apart and seeing all needs to be replaced I think I'd be as well off getting a disc set up for the front. I see the discs are offered in both 5 and 6 lug and I don't know which to get. I can understand matching the rear wheels, but my rears are 8 lug right now, so is there any reason to choose 5 over the 6 for the new fronts? I do plan to change the rear end in another year or so- am I more likely to find a 5 or 6 lug doner for the rear?
    Also, I know a couple of guys here have put a half ton axle on a 3/4 ton truck- anything I need to look out for?
    thanks for the help-
  2. WHITEBULL
    WHITEBULL Member
    Portola,CA
    I went with the 5" 4 3/4 pattern because of the rim availability. More choices with this setup, as you can use almost any Chevy rear end, rims, etc.
  3. drummin52
    drummin52 Member
    Wapwallopen, Pa
    I am one of those who installed a 1/2 ton axle on my 52 3/4 ton truck and did not run into any problems in the swap. All the 3/4 ton parts bolted directly up to the 1/2 ton axle. I also installed a 5 lug disc brake kit and power steering as well and so far haven't seen any problems there either. Just for the record my truck is not on the road yet.
  4. hardcrab
    hardcrab Member
    Northern Neck of VA
    Thanks guys-
    Have you changed your rear set up yet? If so, what did you use?
  5. drummin52
    drummin52 Member
    Wapwallopen, Pa
  6. Kens 50 PU
  7. mikesters1950
    mikesters1950 Member
    Roseville USA
    Chris,
    Are you running a toyota steering box? Where does the power steering pump mount. I think I may see it just below the alternator. I have an a/c compressor in that spot, but would maybe like to convert it to p/s also. Can the same setup be done with manual steering box? Just swirling around some ideas.
    Thanks.....Mike
  8. BIG CHEVY 3600
    BIG CHEVY 3600 Member
    Dallas
    decide on what rear you will use first. Best bet is to go ahead and buy the rear so you will not have to search when you need it. That is if you have room in your den for it.:D
  9. ol' chebby
    do the rear first, then match it. I find that F**d has a greater selection of factory steel wheels, that look old school. There are also lots of other cars and trucks that use 5x4 1/2 pattern.
  10. drummin52
    drummin52 Member
    Wapwallopen, Pa
  11. Bill Hanlon
    That's the same kit (although I bought it from Br0ther's) that I put on my '57. Beware of bump steer if the drag link isn't parallel to the ground.
  12. mikesters1950
    Roseville USA
    Chris,
    Thanks for the great pictures. That helps a lot. I will save them for reference. Still unsure which direction I may go........Mike
  13. Zig
    ~Pictures~ of a 6-lug disc conversion
    Thanks to Bill Hanlon, I spent a fair amount of time over on the "G" site. Here is a link to some great pictures that show a CPP 6-lug, disc brake conversion.
    (I just L-O-V-E pictures!!!):D
    Hope it helps anyone who might be thinking of doing this...
    http://jbhardin-gallery.com/trucks/54gmc.html
