Tie Rod install help
Discussion in '1947-1954' started by cmkruse, Jun 7, 2009.
  1. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Hey Guys (Gals), I just upgraded to the newer style tie rod ends on my 1/2 ton and the tie rod looks like it is really low (like it hangs well below the axle )when the rod is installed with the tie rod ends inserted in the steering arms from the bottom. Is this the correct way or should It be installed from the top down? :confused:
    55.2 thru 59 is from the top. I'm not sure about ADs.
  3. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Tie Rod Install
    Thanks Bill. Mines a 49 so maybe someone that has done this upgrade will chime in. I'm tempted to just do it but I'd have to switch ends to make the grease fittings accessable. :D
  4. Keystoner
    Keystoner Member
    Pennsylvania
  5. Greg_H
    Greg_H Member
    did the upgrade on my 54 and the tierod is on top pointing down.
  6. mikesters1950
    mikesters1950 Member
    Roseville USA
    Craig,
    Sent you a private message also. The tie rod should mount on top, unless you have a dropped axle, according to the instructions. It really shouldn't matter, as long as there is clearance for everything. Mine is on top, but I will recheck after I install the dropped axle.........Mike
  7. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Tie Rod Install
    Thanks Guys, Will getter done thanks to Mike's and everyones help. :D
