rear shocks
Discussion in '1947-1954' started by dorcutt, Jun 8, 2009.
  1. dorcutt
    dorcutt Member
    Keep the truck in VT
    I need to replace my rear shocks on the 51 half ton. I have one strut that is 2 inchs shorter than the other static. Any recommendations? I didn't find a lot when searching on this forum. Thanks, Dave.
  2. Kens 50 PU
    Dave, most of your FLAPS will carry replacement shocks for your truck. NAPA part #94004, Monroe part #33049 to name a couple.
  3. HP53Deluxe
    HP53Deluxe Member
    Virgina
    Ken,
    Don't put that parts book away yet! While your at it, what are the numbers of the front shocks? Mine is a '53 1/2 ton, I assume the rear are the same as the '51.
    Thanks,
    Howard
  4. Kens 50 PU
    Howard, yes the rear shocks would be the same for the '53. The NAPA part# is NS 5826 for the front shocks for the '53.
  5. HP53Deluxe
    HP53Deluxe Member
    Virgina
    Thank You!
    Howard
    Be Smart !
    And use gas charged shocks , they'll ride nice but make it handle better , last longer, be safer etc. , etc.
    You can always peel the labels off and sprasy paint them black if the modern look offends you :rolleyes:
