Signal wiring
Discussion in '1955-1959' started by cosmo1957, Jun 10, 2009.
  1. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    I have a 8 prong plug on my tilt GM column (Delco Remy plug 08 67)
    and need to wire into the 1957 Wiring Harness ......anbody have a clue what goes where ? Or if I can find the diagram for the column plug I have now?
    Shawn
    I don't have a diagram of the stock plug, but I do know the color codes from it.
    Light Blue - to LF turn lamp
    Yellow - from flasher
    Dark Blue - to RF turn lamp
    Pink - to LR turn/brake lamp
    White - from brake switch
    Violet - to RR turn/brake lamp
  3. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    Thanks Bill
    Any idea what the wires are that come out of my later model GM steering column ?
    It has an 8 wire plug......delco remy ...the plug is radius shaped , so I need to see if I can get the proper end from CPofA and do some splicing !!
    Took the truck on its maiden voyage on Sat .........its been 15 long years since I last drove her!
    Went 2 blocks to the Legions cars show .....
    I think power steering is in my future !
    Shawn
  4. azcarman411
    azcarman411 Member
    Rimrock, Az
    Maybe this will help......Chris
  5. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    Chris,,,,
    You Rock !
    Thats exactly what I needed to hook up my column wire to the harness I bought !!
    I pigtailed each wire to trial the lights and it worked perfectly ........
    Thanks !!
    Should be on the road within the next week or so !!
    Shawn
