What is the appropriate transmission ?
Discussion in 'Performance, Engine, and Transmission' started by LORD, Aug 29, 2009.
  1. LORD
    LORD Member
    Hi everyone
    I have a GMC pickup truck model 1979
    Details of the engine:
    Seasoned 454 block 1 or 2 pc rear main seal
    • Bored and honed with deck plate
    • Mains have been aline honed
    • Block as been decked .020
    • Dura Bond bearing installed
    • Brass freeze plug and oil galley kit installed
    • Block painted with 3 coats of high temp ceramic engine paint customers choice of color
    • New Eagle Cast Steel Crankshaft 4.00 Stroke
    • New Eagle I-Beam Connecting Rods With ARP Bolts And Bushed Pins
    • Keith Black Hypereutectic Coated Skit Pistons (10.2:1 Compression When Used With 118cc Head And Standard .041 Thick Head Gasket)
    • Clevite P Series Rod And Main Bearing
    • Hastings Cast Rings Hand Filed To Match Application
    • The complete rotating assembly will be balanced
    • Three piece true roller timing set
    • Custom Ground Hydraulic Flat Tappet Performance Street Camshaft With A Muscle Car Chop
    • (16) New High Rev Lifters (Anti-Pump up)
    • Dart Cast Iron Cylinder Heads
    • (8) Stainless steel 2.300 intake valves
    • (8) Stainless steel 1.880 exhaust valves
    • (16) High performance valve springs and retainers (to match camshaft)
    • 7 / 16 screw in studs and hardened guide plates
    • (16) Chrome Moly push rods
    • (16) New Performance Long Slot Rocker Arms W/1.7 Ratio
    • Engine Will Be Assembled With All Brand New Bolts
    • High Volume Oil Pump And Screen
    • Chrome Oil Pan
    • Chrome Dip Stick And Tube
    • Chrome Timing Cover
    • Professional Products Performance Balancer
    • Fel-Pro Performance Gaskets
    • Professional Products performance balancer
    • Edelbrock Performer RPM Or Air Gap Intake Manifold Customers Choice
    • Chrome Thermostat Housing
    • Edelbrock Carburetor W / Electric Choke (Upgrade To A Holley For $ 300)
    • 14 "Chrome Air Cleaner
    • MSD Pro Billet Distributor
    • MSD 6AL Ignition Control Unit
    • MSD Blaster II Coil And Bracket
    • (8) AC Delco Spark Plugs
    • Custom Fit Taylor 8mm Ignition Wires (Color Of Choice Black, Red, Blue, Yellow, Green, Orange No Extra Charge)
    • High Flow Cast Iron Water Pump
    • Chrome Valve Covers
    • Chrome Breather
    • Complete PCV Ventilation System
    The price of this engine for a 10 thousand dollars
    Note
    I want a manual transmission
    Finally
    Don M
    Thank you very much for your help in the problem of chassis
  2. 2tons of fun
    2tons of fun Member
    ninja town
    all the info is absotultey useless....
    what do you what to do with the truck?
    do you want an o/d?
    do you want a go fast?
    do you want a work truck?
  3. LORD
    LORD Member
    Sorry
    I'm not an expert in these matters
    do you want an o/d?
    I did not know what you mean
    yes
    yes
    I think that the size and engine power-related
    Must be commensurate
  4. 2tons of fun
    2tons of fun Member
    ninja town
    o/d- over drive?
    then you are going to what something like a nv4500. low first gear, tough, overdrive. they are not gear slammers or quick shifters but they are renowned for strength and versatility.
  5. LORD
    LORD Member
    Can you put a link to such transmission of this
  6. 2tons of fun
    2tons of fun Member
    ninja town
    what kind of link?
  7. LORD
    LORD Member
    Link to any manual transmission, you are nominating
  8. 2tons of fun
    2tons of fun Member
    ninja town
  9. LORD
    LORD Member
    Thanks 2tons of fun
  10. drabo
    drabo Member
    Patrick AFB, Florida
    The transmission needs to be sized to the horsepower of the motor.
