Tilt Wheel Column
Discussion in '1973-1987' started by rickrs, Sep 12, 2009.
  1. rickrs
    rickrs Member
    Does anyone know if the rod that actuates the ignition switch is different on a tilt-wheel column or if the steering column jacket (the sleeve that covers everything) is different.
  2. texascowboy
    texascowboy Member
    Texas
    I could be wrong, but I don't think there is a differnce. I took a steering colum out of a 74 and put it in my 83 and there was no differnce. Hopefullay someone will correct me if I am wrong. Good Luck.
  3. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    There is a differents from a upper none Tilt column and a Tilt column case and upper guts but the rods should be the same.
