parking light re wire
Discussion in '1960-1966' started by sleepysal, Sep 7, 2009.
  1. sleepysal
    sleepysal Member
    Hi I have not posted for a while, but wanted to pass this tip on to you all.
    My 60's parking lights never worked,this is due to the fact that there was no wiring to the parking light circuit.
    I decided to wire the parking lights to the low beam light circuit. I had added relays to the high/low beam so I just tapped into the lead coming from the realy to the low beam headlight . easy . Having not had parking lights this worked out for me here is a link on what to do if you have working parking lights:
    http://www.6066gmcguy.org/parklamp6063.htm
    and this is what mine look like when they are on , not to bad
  2. gulffishin
    gulffishin Member
    Alabama
    That looks good, my parking lights only work without the headlights on; either headlights or parking lights.
    Do your blinkers work with the parking lights on?
  3. sleepysal
    sleepysal Member
    yes the turn signals work with the lights on,if you look at yours you will see that there are two wires going to the turnsignal/parking lights so they are two seperate circuits
  4. dvalentine
    dvalentine Charter Member
    Sacramento
  5. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    yep works perfect, thats how i did mine.
