Vin Locations
Discussion in '1947-1954' started by catman07, Oct 27, 2009.
  1. catman07
    catman07 Member
    Where are the VIN locations on a 1954 GMC 100 pickup?
  2. azcarman411
    azcarman411 Member
    Rimrock, Az
    The VIN #'s are stamped on a plate on the drivers side door jamb hinge side. No stampings on the frame. Chris
    Vin
    FWIW
    When your truck was new , they most often used the engine's serial number as that was the most valuable part of the vehicle then .
    So , check it agaionst your title and if no match on engine nor door jamb data plate , you'll need to get a title correction , DO NOT just run down to the local PD or DMV ! .
    There's a bit more to it that'll save you headaches and money too .
    I and others who have done this , will be glad to explain it all later , I'm rushed right now .
    BTW : once in a great while you'll find a number stamped into the top frame rail near the steering box , it'll be covered by the left inner fender piece .
    I've seen it on the crossmember too , right under the cab .
    These numbers may or may not match the data tag's VIN .
