radiator
Discussion in '1960-1966' started by Superman, Dec 29, 2001.
  1. Superman
    Superman Member
    I have a 1960 pickup, with a 454, I was wondering if anybody knows if a radiator from another vehicle would fit, that will be able to cool the big block? Thanks.
  2. 63Truck
    63Truck Member
    WOW a 454.... Your lookin at a custom setup or at least fabricating the front end.... Most places can hook you up with a radiator That will work ... it's getting it to fit thats the catch... I believe that the widest you can install from a stock point of view is 25" across....
    1963 Chevy 4x4 1/2 ton
    350/400/NP205/3.73
    33X12.5X15 Fun Country
  3. ChevyOnly
    ChevyOnly Member
    I'm not sure of another model that u can use, but you can always take it to the rad shop and get the original rad re-cored to a 4 core. What do you use to cool, maybe try electric fans 2x8" or one large one, then you might not have to spend the $$$$ for a re-core and you will have the benifit of electric fan on a switch for plowing threw the water.
  4. ChevyOnly
    ChevyOnly Member
    Sorry i thought you had a 4x4. But the electric fans should do the job.
  5. rustbucket
    rustbucket Member
    New Braunfels USA
    Hey S,
    So YOUR the guy that had the user name I wanted!
  6. cori
    cori Member
    HI SUPERMAN I HAVE A NEW ONE THAT I BOUGHT FROM A LOCAL SHOP,4 CORE FITS IN THE STOCK RAD SUPORT, NEW NEVER USED FOR $425.00 CAN.I AM WILLING TO SELL IT AS I WILL NOT NEED IT FOR A WHILE (AND I NEED THE CASH!)
    CORI :)
