What to do with those old hub caps that are just laying around
Discussion in '1960-1966' started by bigtimjamestown, Feb 6, 2010.
  1. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    Instead of filling those old hub caps with nuts and bolts I decided to make air cleaners out of them.
      File size:
      78.8 KB
      497
  2. Vin63
    Vin63 Member
    SoCal
    Ahhh...very cool! they resemble the style/look of the tops of the old oil bath air cleaners.
  3. Jonnygogo
    Jonnygogo Member
    Brooklyn, WI
    Recycle, Reuse!
    Recycle, Reuse!
  4. markeb01
    markeb01 Member
    Spokane, WA
    That engine is as beautiful as the truck it's in. While your hubcaps are earning a living, mine just lounge around serving as garage art.
  5. bigtimjamestown
    Jamestown Ca.
    Thanks Marke, I've built a lot of trucks through The years but I've been on a mission with this one to see how cheep I could build it. My "61" was built With a bunch of parts from different trucks and with no expensive kits. It still has the torsion bar suspension but with power disk brakes , power steering and a auto trans. with a late model rear end.:)
  6. LEYLAND
    LEYLAND Member
    Ontario, Canada
    That intake is a nice touch, the hubcaps definitly set it off!
    you mentioned a late model rear end.. what are you using?
  7. bigtimjamestown
    Jamestown Ca.
    Thanks Leyland, I wanted my "61" to look like one that someone had fixed up along time ago. I had bought a mid 70's Chevy truck for 400.00 and striped it. The rear end came from that truck as well as the disk brakes, power steering, power brakes, upper a arms, spindles, motor mounts, trans cross member, trans, all the brake lines and all the little things like special clips and hardware. Then I sold what I had left and got my money back.
  8. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    again, very cool, i love taking old things and making them into new things with different purposes so what youve done is what i really like.
