spindle and break ?
Discussion in '1960-1966' started by hamrs_62, Feb 17, 2010.
  1. hamrs_62
    hamrs_62 Member
    empire, ca.
    the p.o. of my truck, put new spindles and disc breaks on the front, well when he did it threw the front wheels out about 21/4 inches out further than the rear, is this normal for this app. this seem a bit much, has anyone else done something similar with different results with other spindles,
    thanks
    ps, spelled brake wwrong
  2. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    What spindles and disk brake set up did the P.O. use? Do you still have torsion bar suspension? What rearend are you using? Are the front wheels 2 1/4" wider over all or 2 1/4" wider on each side? What wheels are you using and are they the same offset as the rear? We need more info.
  3. hamrs_62
    hamrs_62 Member
    empire, ca.
    each side is 2 1/4, everything else is still there, it has a camaro rear end, the wheels are chevy rims with the rings, and they are the same
  4. hamrs_62
    hamrs_62 Member
    empire, ca.
    looks like your just up the road
  5. bigtimjamestown
    Jamestown Ca.
    Yeah I am just up the road / hill. Looks to me like the wheels you have on the front are pretty deep. I think if you run those wheels that they will stick out past the fender. I run a stock 15x8 truck rally and it seems to fill up the fender well. Here's some pix and a link that might help and give you some Info. I will be in Modesto on Sat. Maybe I can take a look. http://www.chevytrucks.org/tech/ifs&rearend.htm
      File size:
      131.5 KB
      390
  6. hamrs_62
    hamrs_62 Member
    empire, ca.
    yes they are a bit deep, but with that they should track the same as the rear , right,
  7. bigtimjamestown
    Jamestown Ca.
    I'm guessing that your Camaro rearend is out of a 67-69 which is Aprox. 2" narrower than the Orig. 62 truck rearend. I think there is also too much offset in your front wheels and your tires will stick out of your fender wells by at least a couple of inches. You are using the stock suspension with disk brakes which is the same thing that I'm using so I don't think there is any problem there. http://www.quickperformance.com/Technical Info/sus_measure.htm
  8. hamrs_62
    hamrs_62 Member
    empire, ca.
    so the best situation would be to get narrower wheel and maybe some front wheels made so the front wheels set in further
  9. bigtimjamestown
    Jamestown Ca.
    It looks like you have a set of custom made rallys. If you like what you have you might hang the rear fenders and see if the rear wheels fit under the fenders ok and just get a set of 15x8 rallys for the front. Deep dish wheels always look good on the rear. You also might check with Stockton wheel and see what they have. I think they make wheels there or they can at least get you what you need and they might even do some trading with you.
  10. dvalentine
    dvalentine Charter Member
    Sacramento
    The conversion to disks WILL pitch the front outward but not 2 1/2 inches per side. I think normal would be about an inch and a quarter per side.
    dv
