Carter YF with auto choke , Fenton dual intake
Discussion in '1947-1954' started by Blueflame236, Feb 15, 2010.
  1. Blueflame236
    Hey guys
    Has someone any experience using the Carter YF with auto Choke combined with Fenton or Offenhauser dual intake ? Will it give any better engine performance using this 2 instead of one carb? What about petrol econemy ?
    Martinius.
  2. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    I ran a Fenton with 2 singles about 30 years ago. 2 is always better than 1 but you will probably want to upgrade your ignition. Just a coil would be a big improvement and a MSD box is even better. As far as millage go's....Who cares! lol :D
    YES and YES AGAIN !
    It will both increase the power greatly and also improve the fuel economy due to more precise metering of the fuel....
    Even if you run two Rottenchester leaks-a-lot Series 'B' caries on a Fenton intake , you'll have better power and economy .
    Remember though : both carbys *must* be set up and adjusted (jets etc.) exactly the same or it'll run terribly .
  4. Blueflame236
    What i have Nate is 2 off a kind carbs with autochoke for 235 Ci engine . Does it matter if i use these or will the result be better with manual choke carbs ?
    Martinius.
    Well Then ;
    Use whatcha got there ! or as we say in America : Run Whatcha brung :)
    The chokes make no difference at all , they *might* help in extremely cold weather starting .
    If it were me , I'd only connect up one choke and leave the other adjusted wide open regardless of temperature .
    A good running engine only needs the choke for 30 ~ 60 seconds MAXIMUM , then your right foot or the throttle wire should be sufficient to keep the engine running , too much fuel is always a bad thing as it causes extremely rapid engine wear .
    I hope this answeres your question ? .
    if not ask again ! :p .
  6. Flashlight
    Flashlight Member
    Martinius,
    For what its worth...I put two Rochesters on my fenton intake. It has a manual choke set-up on them so I used them. The choke cable is on the rear Carb as in a stock single set-up.
    It is not cosmetically pleasing at all as the cable looks bunched up on the firewall because the rear carb sits so much further back on the manifold. I think you will be happier with your auto-choke set-up as Nate describes.
    Flashlight... near Viking Mountain (1600mtr) Tennessee
  7. Blueflame236
    Thank you again guys for all the help. Its good to know that the choices one makes is well founded when changing a standard arrangement.
    Its allways a cost/benefit question and there is an esteticall side included offcourse to.
    Have a nice day Martinius.
  8. Flashlight
    Flashlight Member
    I also can't find a nice place to put my glass bubble type fuel filter. I wanted to show it off and make it easy to see. I have not found a good spot for it. You know how much we pay for these and to not use it really bothers me. It looks great on my single carb set-up in the 47'. But the dual carb setup precludes using the same spot. Any idea's.
    Flashlight
  9. Kens 50 PU
    Couldn't you put one on each carby on a 45 degree angle and hook up the fuel lines to them that way?
    Glass Bowl Fuel Filters
    What Ken said ~ if you peruse pictures of various dual carby setups , you'll see how they manag it with angled fittings .
    You can use the dual feed pipes from 4 BBL Carter carbys on dual single carby setups to make tem look nice .
  11. Blueflame236
  12. Zig
    Truck porn...
    I'm all hot and bothered after watching those videos.
  13. vwnate1
    ' Truck Porn ! '
    InDEED ! :D
    I got lost in watching / listening to old Babbit pounders roaring away....
    I guiltily looked over my shoulder to see my sweet has fallen asleep in front of the TV ..... :p
    Those videos make me want to go drive my truck around and it's bed time Sunday evening....
    BTW : I have NO MUFFLER and my 235 sounds great ! not too loud .
  14. Bill Hanlon
