Orginial Motor Lifting Brackets
Discussion in '1967-1972' started by steve, Jan 9, 2010.
  1. steve
    steve Member
    Virginia
    Hello everyone,
    I have a 1972 350 motor that I will be installing in my 1959 truck, I would like to know if anyone has pictures of the stock lifting brackets located on the intake manifold and in the rear of the 350 engine. I like to used them to install my 350 engine. But need to see the correct location.
    Steve:)
  2. drabo
    drabo Member
    Patrick AFB, Florida
    I'm not sure they came on the blocks back then. But if you want to install a set they are bolted to the heads. Also there is a lifting bracket that bolts to the intake where the carb goes and works quite well. You can find them at any parts store for about $20.00.
