A terminal / B terminal at generator
Discussion in '1947-1954' started by wokri, Feb 23, 2010.
  1. wokri
    wokri Member
    Germany
    Good morning together,
    what is the A terminal and B terminal at the generator. At Bosch generators you find B+ and D+ and DF and D-. I've read the wiring installation information but I don't understand it right. :mad:
    Wolfgang
  2. ol' chebby
    On the stock generator, looking from the front, the terminal on the right is the field, the left is batt.
    Generator Fun
    Good morning Wolf ! .
    The 'A' terminal id the armature or D+
    The 'B' terminal is the DF
    Delco generators are 'A' circuit so to test you bridge the A & B terminals then spin it at idle , never ground the field like on a BOSCH ('B" circuit) Generator !.
    Do not EVER rev. the engine over 1,200 RPM's when testing as you'll burn it out .
    DO NOT " flash " or " polarize " the generator ! . this is a last ditch " Hail Mary"
    thing done only if the generator has reverse polarity or other malady .
    Connect it all up and start the engine , rev. slowly and observe the voltsge begin to rise to about 7 VDC at the battery .
    If no charge , STOP and let us know , we'll walk you though simple generator testing .
  4. wokri
    wokri Member
    Germany
    Thanks for posting!
    :D Thanks all!
  5. wokri
    wokri Member
    Germany
    Voltage F terminal to generator F terminal?
    Hello,
    can someone tell me what is generator F terminal.
    In my wiring instructions is wirtten no. 24 voltage F terminal to generator F terminal. What means F terminal on a Bosch generator?
    Asks
    Wolfgang
    F Terminal
    Is for the Field or exciter curcuit .
    Grounding this forces the generator to produce maximum current so ! DO NOT ! Rev. the engine a bunch whilst testing when it appears to not be charging ! if it suddenly begins to charge , you'll burn out the armature before you can blink .
