fuel guage problems
Discussion in '1973-1987' started by tylerb826, Sep 27, 2005.
  1. tylerb826
    tylerb826 Member
    I have a 1975 K10 4x4. Everything works as it should. When I bought it the guy had took out the fuel guage because it did not work. So after many times running out of gas I finally decided to put it back in to see if what he told be was true. When I hooked it up the needle move to 3/4 of a tank. I thought it was working so I drove it through town to see if it would move as the gas was move around and drunk up by the built 350. Sadly it never moved. So I put a new guage in that needle didnt move at all. So is it the sending unit or have I wired incorrectly? It could be that there is more than on wire from the tank and Im not sure which is the correct one. And how many wires should come from the sending unit? Please help this important! :-(
  2. markh
    markh Member
    saint john canada
    try the ground wire on the sending unit . this will take two people one to watch the gauge and one to try the wire
  3. markh
    markh Member
    saint john canada
    sorry ,there should be three wires to the sending unit
  4. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    GROUNDS clean them grease them make sure con. good
    YES the bigest trouble with sending unit is the ground after year "rust, winters, air, sand,"bad conection.
  5. mcook
    mcook Member
    My unit has on two wires. One positive and one ground and my gauge only reads 1/4 tank. What should I do.
  6. 58Apache250
    58Apache250 Member
    Darlington USA
    A Good Customer of mine (all he uses on his farm are Chevy trucks:D), Brought his '87 short bed to me with the same problem (Reads 1/4 tank all the time). After going through all the basics, and verifying no problem with the sending unit , or wiring, I suspected the gauge. 1947-1987 fuel gauges work basically the same: Low resistance= Low Gauge reading. High Resistance= Higher reading. @ Full the Sending unit read 150 Ohm, But it took 320 Ohm to make the Gauge read "Full". Gauge was replaced, correcting the problem. Also, Make Sure there are no "Mickey-Mouse" Splices in the Gauge wire, and that you have a good ground. Unless there is an in tank pump, there will be either one, or two wires.
  7. bodycount
    bodycount Member
    just go to rockauto you can get senders for like 20 bucks :)
  8. heavy chevy 4x4
    heavy chevy 4x4 Member
    pageland SC
    my chevy only has 2 wires and mine works fine
