216 oil gauge with a 235
Discussion in '1947-1954' started by Volker, Apr 16, 2010.
  1. Volker
    Volker Member
    Germany, nearby Leipzig
    my 235 has 45psi oil pressure. The end of my oil gauge shows 30 psi max. My oil gauge shows always maximimum. What can i do???
  2. Flashlight
    Flashlight Member
    Gruss gott Volker,
    The old 216 was a low pressure motor, 10-15psi when cold and lower when warm. The 235 is a new High pressure design and can run 30-45 psi. The oil pressure gauge can be swapped out and a rebuilt gauge can be ordered from Classic Chevy which runs to 60psi.
    Flashlight
  3. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Thank God
    That you have great oil pressure. For the 47-54 they make 60psi guage replacements. I'm not sure about your 46...have you checked your catalogs?
  4. Flashlight
    Flashlight Member
    Good point Larry, I forgot his gauge design is different the the AD gauge.
    Flashlight
  5. Blueflame236
    Classic Chevy adres ?
    As i have to change the gauge setup to i wonder if you mean Classic Chevy in Michigan Sir?
    Regards Martinius.
  6. Flashlight
    Flashlight Member
    I mean our sponsor, Jim carter also has rebuilt gauges. Carter may also have a gauge for Volker as he has a 41-46 catalog.
    Flashlight
  7. ccharr
    Hook up another new onw until you get the one inside the dash rebuilt to your liking. And drive it like the wind.
  8. Volker
    Volker Member
    idea
    i found a pressure control valve for an oil heater (from the heating system in my house) and they divided the input pressure by 3. i will buy this part (cost approx $20) and come back with information. If its work then i can redesign my temp gauge scale and use it.
    Oil Pressure
    I'm not understanding why the heck you want to change it......:confused:
    I ran my '46 3100 like this for 13 years of hard work , Commercial Service , I was always happy to see the oil gauge pegged as soon as the 235 went above idle .
    These are low pressure , high volume oiling systems so if it shows *any* pressure , you're good to go .
    No need to install a '47 ~ '53 GMC gauge with a Chevy gauge decal on it as far as I can see but that's the fix .
  10. Volker
    Volker Member
    i won't change it but i thought if its every time on the end of the scale it works not so long. after this weekend i let it as is. the oil presure swinging and the gauge not leaking. aslo it's not critical and i can see if the pressure goes down. thats enough for me.
    Volker
