Project photos
Discussion in '1947-1954' started by dorcutt, Apr 27, 2010.
  1. dorcutt
    dorcutt Member
    Keep the truck in VT
    I have tried to add some photos of my almost completed project. Thanks to all on this forum who have helped me. It has been a journey, Dave
  2. Wolf
    Wolf Member
    Kansas
    WOW so this is your truck!!! Very very nice!!!
  3. JW 54
    JW 54 Member
    Cypress Texas
    Nice!!!
    You've done a great job Dave. No snow in the Great White North??? It's not even June. Mild Spring Ay?
    Enjoy the fruits of your labor.
    JW
  4. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Nice job! And green grass already to be mowed!
  5. dado
    dado Member
    Bogart
    Nice very Nice ! where did the carbs come from ?
  6. Kens 50 PU
    Sweet!
    Looking good there Dave. Now it's time to cruise!
    Enjoy it!
    Ken
  7. Zig
    Zoom Zoom in RED!
    That is a fine looking truck! I love the ventilation you have on that! What about the wheels? Are you leaving them as is, or looking for some "bling"? Will this be a work truck now?
    Whatever it ends up, DRIVE that thing and start turning heads! :cool:
  8. dorcutt
    dorcutt Member
    project update
    Zig, It it intended to be a work truck. I just changed the wheels from 15 inch to back to the original 16 inch, and put on new tires. I was looking for the the original look some what and I think this is getting there. I am looking for some original hub caps for the 16 inch wheels and I suspect our sponsor has them but there not cheap. It dose need something for that "bling" look.
    dado, the carbs are Toms Langdons and installed pretty easily although I am still tinkering with the throttle linkage. They started right up and sound great with the dual exhaust.
    I still have some work to do but it is a work in progress. I need to start driving it to see what else it may need and get my confidence up. Hopefully not much more.
    The pictures were on an good day as we just had 3 inches of snow here in Montreal but spring is around the corner.
  9. Blueflame236
    Nice looking engine with dual carbs setup.
    Hey Dave
    You have done a nice work here and thanks fore the pics. I am always cureous about the functionallety and how the engine runs, carb setup ect. It would be great if you could share your thoughts with us around that question . Did you use Tom Langdons dual carbs setup ?
    Martinius. :)
  10. dorcutt
    dorcutt Member
    Martinius, I did use Toms set up. Even for an amateur like me they went on fairly easily. I did the pre heater tubes off of the Fenton headers, not the hot water connection off of the radiator that Tom recommended. The electric choke was a no problem. My only area I am having a challenge with is the throttle linkage from the carbs to the pedal. I made up a new throttle rod from the pivot point on the engine to Toms linkage and it works OK but I think it can be improved yet. My throttle spring may be too stiff.
    All and all it seems to be a neat set up and it started right up with no issues. I like it better than the dual Rochester's that I originally had. I had nothing but fuel leakage problems with them which just did not set well with me. Something about fuel dripping on a hot manifold that just did not seem right.
    There was a lot of info on the forum that help me. Another Dave has a great set of pictures that I used as a reference on this site. And as always Nate was a great source for keeping me straight. Hope this helps, Dave.
  11. vwnate1
    Dual Carbys
    WOW ! sharp looking rig there .
    Are those Solex or Webers ? .
    Rochesters can be made to leak less by lowering the float height , you won't run it too lean doing this if you have dual carbys .
    Or , you can glue the air horn gasket on.... :rolleyes:
  12. mobileortho
    mobileortho Member
    Hampton, VA
    Great looking truck. Love that engine!
  13. dorcutt
    dorcutt Member
    Nate, the carbs I installed are the carter webbers from Toms place. Dave
