Back from paint
Discussion in '1973-1987' started by David Hall, Oct 21, 2008.
  1. texascowboy
    texascowboy Member
    Texas
    glad to hear at least the front is done, I had the same problem when I put my bumper on, everything was straight but I had to use spacers and it worked out good. wish you the best.
    School....:confused:...:eek:...that's a bad word!!!j/k hope it goes well for you.
  2. David Hall
    David Hall Member
    Chesterfield Va.
    I've been busy as hell lately, but here's some progress pictures.
    1. Front & Rear bumpers mounted
    2. Fuel line completed and installed
    3. Radiator, fan and pulleys installed
    4. Windshield wiper system installed
    5. Cowl screen and cover installed
    6. Autometer sending units installed
    Currently working on the distributor and should have it in by the end of the weekend
  3. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    looking good!!:):):eek::eek::D
  4. The Carpenter
    The Carpenter Member
    Valrico, Florida
    I think that truck is the most beautiful thing i have ever seen. Really.
  5. David Hall
    David Hall Member
    Chesterfield Va.
    Thanks.
    Would be posting progress pics but the camera batteries quit taking a charge.
    The truck is coming along slowly but at least its coming together.
    I'm surprised at how long all the little things take to get just right.
  6. David Hall
    David Hall Member
    Chesterfield Va.
    Progress Pics
    Here's some pictures taken over the weekend. I'm on my 2nd radiator overflow bottle that leaks, so that will have to come back out. I spent most of sunday getting the gauge cluster ready, still needs a little work and I want it in for the initial start up to help monitor the engine. I'm going with the idiot light set up and AutoMeter oil pressure / water temp gauges. Still up in the air where exactly to mount the gages, any ideas?
    MSD Distributor installed
    MSD Plug wires installed
    Throttle and Transmission Cable installed
    Yellow Optima battery and cables installed
    Moroso air cleaner installed
  7. David Hall
    David Hall Member
    Chesterfield Va.
    Still More Progress
    Finally got around to installing the grill and head light surrounds. Lately (depending on the weather) I've been jumpin all around the truck workn on different things. I have started it up and taken it on a short drive with open headers, tryn to work out a few bugs.
    I feel like I'm rounding the corner with this project but I know it will never be completely finished.
  8. David Hall
    David Hall Member
    Chesterfield Va.
    It's Been Awhile
    I decided to upgrade the axles, wheels, tires and liftkit.
    There now resides under the rear of the truck a 3/4 ton, 14bolt with 410 gears.
    The front is a 3/4 ton 10bolt with matching 410 gear. The wheels are made by WELD and are 16.5 x 14. Tires are Super Swamper Boggers and are 16.5 x 18.5 x 39.5.
    To make all this work the 6 inch lift had to come out and in went a 12 inch by SuperLift.
    Let me know what ya'll think.
    Thanks,
    dh
      File size:
      135.8 KB
      448
      File size:
      137.4 KB
      476
      File size:
      99.3 KB
      419
      File size:
      90.3 KB
      482
      File size:
      109.9 KB
      470
  9. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Looking Goood :) sweet truck Very well done . A labor of love as Most will see two thumbs up. [​IMG] [​IMG]
  10. David Hall
    David Hall Member
    Chesterfield Va.
    Thanks Pontiac
