a little more done on the 64 gmc
Discussion in '1960-1966' started by 64shortbed, May 24, 2010.
  1. 64shortbed
    64shortbed Member
    scott city ks
    just tought id share a little of what ive got done on the 64. got the frame work in and the metal for the bed cut and put in. still got to make the filler panels for around the wheel tubs and filler neck. only thing i had for cutting the 14 gage sheet metal was a sawsall but to make the filler panals ill use my cutoff wheel. i hope i get it all welded and ready to take the bed off this weekend so i can do the welding on the bottom side so it wont make a bunch of road noise and bounce up and down. and i got my head liner made an put in. i have enough of that material left to cover the seat so im thinking i my have to have that done one of these days.
    well enjoy the pics and let me know what yall think!
    thanks for lookin mark.
  2. LEYLAND
    LEYLAND Member
    Ontario, Canada
    Nice to see an update... I was starting to figure your truck went out the door with your son's truck:eek:
    The bed looks pretty good, nice approach for something a litte different. You should get someone to CNC some real spider web gussets (ok fake gussets but you get the idea) to weld overtop in the corners... I think it would look pretty cool.
    Keep it up!
  3. 64shortbed
    64shortbed Member
    scott city ks
    cnc spider webs thats a kool idea ill have to remember that one:D and here is a couple more pics i started the weldin. around the filler neck is a little funny lookin but i have a flux core welder and i was havin some problems there:) but ill grind em down and theyll look good then.
      File size:
      100.7 KB
      304
      File size:
      81.3 KB
      334
      File size:
      121.8 KB
      353
  4. johan
    johan Member
    Varney Ontario
    looking good
  5. LEYLAND
    LEYLAND Member
    Ontario, Canada
    :eek: Time to invest in a tank for that welder...
  6. 1965GMC
    1965GMC Member
    i'm rebuilding a 65 GMC, would you have a spare tailgate laying around?
  7. 64shortbed
    64shortbed Member
    scott city ks
    sorry bud i only have the one im using. i do have a delux heater for a gmc or a chevy. (i have the contols for either one) and the rest of the heater. other then that i got the horn button. the cowl end pieces. and a few extra parts.mostly small parts. only big parts i got is a 60-61 chevy hood and a 64-66 gmc hood. if u you need any thing i can see if i got it.
  8. gulffishin
    gulffishin Member
    Alabama
    Headliner?
    How did you make/ attach your headliner? I have been wanting to make a headliner, but am not sure how to attach it.
  9. 64shortbed
    64shortbed Member
    scott city ks
    i just used self tapping screws . ill change em out later for the ones with snap covers
  10. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    Here's some pix of my head liner, door panels and kick panels I made over the winter. They were cheeeeeeeeeeeep to make and makes the truck look a lot better inside....Big Tim :cool: 003.jpg
  11. LEYLAND
    LEYLAND Member
    Ontario, Canada
    Nice job! will help with sound deadening too.
  12. gulffishin
    gulffishin Member
    Alabama
    It's looking good!
    Tim, What did you make your headliner and door panels out of? fiberglass?
  13. bigtimjamestown
    Jamestown Ca.
    The material for the door panels kick panels and the lower door panels is 1/8" masonite. You can get a sheet of it cheep at most hardware stores. The bowtie and raised trim on the headliner are just pieces of the same material I cut out and layered on top of each other. the raised parts on the lower door panels are 1/2 round wood trim you can buy at most hardware stores.The SS trim and pocket are out of a mid 70's Chevy pickup. The most important thing to do is make sure you use the right glue because most glue will release when the temperature gets hot. I've experimented through the years with different glues, 3m is crap as well as most anything you can buy in a store. So here's the 2 kinds of glue I have used that has held up to the California heat . Gorilla Glue for the wood parts and V&S high strength adhesive # 1090 which is 6.99 a can plus shipping ( buy 4 cans) at this website http://www.glueplace.com/products/V&S-High-Strength-Adhesive-%2d-#1090.html If you don't use these glues all your hard work will go to waste. I don't use any tacks or staples when attaching the material to the wood or metal and if you try to use any foam padding the material will release it self. With the 1090 glue you have about 5 minutes working time, when you spray the glue on, spray it on kinda thick allow about 2 minutes to tack up you don't want it to be wet and you don't want it to be dry just tacky. Have your material laying flat on the table face down then lay your panel down on top. Turn the whole panel over and work the material from the center out and remember you only have about 2-3 minutes to do this. After you are satisfied with the way the panel looks turn it over and spray more glue on the back side around the edges, let it tack up and fold the remaining material over. Do Not use a heat gun this will only speed up the drying time and your materials will not stick together. I was able to do this for less than a 100 dollar bill. I hope this helps those of you on a budjet like myself.....Big Tim :cool:
