Gas Tank Painting
Discussion in 'Paint & Body' started by blackbeard, Sep 1, 2008.
  1. blackbeard
    blackbeard Member
    Just recieved my new gas tank for behind the seat of my 59 Chevy truck. The tank is galvanized. Just wondering if I should prime and paint the tank before I install it or leave it bare metal. It looks like the old tank was painted on the front and un-painted on the back.
  2. 64shortbed
    64shortbed Member
    scott city ks
    i would say that its up to you how you want it to look. i think if you paint it it will last a lot longer.
  3. chevymantrucks
    chevymantrucks Member
    Lincoln U.S.A
    Hey,
    If it is galvanized it will not rust because galvanizing is a rust resistant coating.I would paint if you want it a different color.
    Cliff
  4. smithshn
    smithshn Member
    It is depend upon you how look you want to want. But if it is galvanized it will not trust able because galvanizing is a rust resistant coating. You can paint it as different color.
  5. 58fleetside
    58fleetside Member
    Boulder, CO
    I primed mine then painted it and the area behind the seat black. Came out pretty good.
  6. BAM55
    BAM55 Member
    Inglewood, CA
    I epoxy primed and base coat / clear coated mine and I like it alot.
