One question of understanding
Discussion in '1947-1954' started by wokri, Aug 18, 2010.
  1. wokri
    wokri Member
    Germany
    Hello,
    how do you call a joint that fix two oil lines to the engine block. It has a form of a "t".
    Ask:confused:
    Wolfgang
  2. Kens 50 PU
    You answered your own question
    It is called a "tee" fitting or simply a "t".
  3. ol' chebby
    It is a brass fitting found in the plumbing section. I am assuming it is for the oil pressure line and filter? I believe it is 1/4" pipe thread, but I may be wrong. Look in the plumbing section at a home supply place, Lowe's, Home Depot, etc.
  4. Larrys 48
    Larrys 48 Member
    Spokane, WA
    I wonder...
    ...how they say "Home Depot" in German?
  5. Flashlight
    Flashlight Member
    I'll take a stab...."Heim Lagerhaus", but not all translations are literal. They do have some large home stores in Germany, but doubtful if any will have non-metric fittings.
    Flashlight
  6. Volker
    Volker Member
    Germany, nearby Leipzig
    In Germany we say OBI or Hellweg or Bauhaus to a DIY market. and Yes they have Fittings with inch. If Not you can go to your Next Installateur for plumbing and waterlines, sorry for the German/englisch mix
  7. wokri
    wokri Member
    Germany
    Thank you for the lesson
    Hello,
    thank you guys for teaching. I ask this question while I had a problem with this fitting. I had made by myself, I can work on machines where I build such fittings. I made it of brass and it broke on the thread that fitts to the nut that is fixed in the motor block. i don't know why maybe it was a assemble fault by my self. The thread that goes to the nut is long enough so I will try to connect it again. I saw it on a web site of our sponsor but i could remember the site and the correct term.
    Background: I'll get today a visit from journalists of a Germany magazine of classic cars. They phone me and ask if they can make a story of restoring a pick up. I don't know how they would like to see my truck. I didn't phone them.
    Wednesday a freind of mine and me we started the engine, it comes immediately but suddenly there was a gread oil puddle under the truck. One flop again.
    Wolfgang
  8. Flashlight
    Flashlight Member
    Hang in there Wolfgang. Hopefully the puddle is only a small fix. Good to see the Deutschland group is still following the blog.
    Flashlight
  9. wokri
    wokri Member
    Germany
    T fitting is closed
    Hello,
    after I had threaded the T-fitting and screwed it to th fitting in the engine block, we started the engine again to see what will happen. Oil is tightly,:D but now the gasket from the manifold makes trouble. :mad:What this is, I don't know. The engine blowes out. Maybe I had pulled the screws in the wrong order, maybe the gaskets are distroyed. I will buy a new gasket, has anyone a good tip where I can get a gasket kit in a very good qualitiy?
    Ask
    Wolfgang
  10. Volker
    Volker Member
    Wolfgang,
    call Patricks. I bought all gasket there and all fits perfect.
  11. ol' chebby
    I used 2 gaskets and the copper RTV sealer between them. Make shure all gasket surfaces are clean before assembly.
  12. wokri
    wokri Member
    Germany
    rtv sealer???
    Hi ol' chebby,
    what is copper rtv sealer? Is this a paste of copper? I uasually take this paste if I fix two exhaust tubes togehter so they can rust.
    Wolfgang
  13. smfulle
    smfulle Member
    Ogden, Utah
    RTV Copper
    Available at most auto parts stores.
  14. Blueflame236
    AU-VE-CO Compression Brass fittings from The Filling Station in Oregon.
    You can buy the original compression brass fittings from the truck/car vendor "The Filling Station" in Portland Oregon.
    Martinius.
