12 volt starter
Discussion in '1947-1954' started by Zig, Sep 12, 2010.
  1. Zig
    Okay~ so I searched the threads. (Well, I did, but I got way sidetracked by all the other stuff that popped up when I put "12 volt starter" in the search box) I could probably spend the evening in there and never find the simple answer I know exists to this question.
    What 12 volt starter will work in our 6 volt starters place? That is, and will allow me to retain my foot stomp starter setup.
    Thanks in advance!
  2. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    The answer is simple Zig and you don't have to do anything at all. Use the 6 volt starter you have with your 12 volt system. It's like having a high torque starter.....Big Tim :cool:
  3. Zig
    Well, I did~ My starter is now past tense.
    It would spin just fine, but my battery was weak, and I had to keep charging it up. I might have tried starting it one to many times on a weak charge? Fully charged battery, hit foot stomp, nadda.
    Maybe the starter was about to crap out anyway.
    I spent more time having the pistons pump via the starter then by the spark from the plugs. Anyway, with a fully charged battery and clamped down connections, I got nuthin.
    Thanks, though, Big Tim
  4. bigtimjamestown
    Jamestown Ca.
    Sounds like you burned up the starter zig, with a properly tuned engine that starter should work just fine because it shouldn't take more than just a few seconds to start. If you spun that starter for more than 30 seconds at a time without letting it cool off then that's what burned it up. also not enough juice in the battery is hard on a starter too. Since you just put a new alternator on I'm guessing that you probably need a new battery and rebuild the starter and you should be fine. And last but not least and I know you have been waiting for this ...... Replace that Jimmy motor with a Chevy and your troubles will just fade away.....lol....Big Tim :D
  5. coilover
    As stated, the 6v works fine if not used for long periods. The 55-59 have a 12v foot stomp starter.
  6. ol' chebby
    Or have it rebuilt. Mine was $115 to convert to 12v and rebuild.
  7. Zig
    Thanks, guys. I guess I check the bone yards for an old foot stomp and the yellow pages for a rebuilder. I guess the auto stores,too. See if they have the older 50's foot stomp rebuilt ones and how much they cost.
    After 4 years of setting and not ever wanting to start correctly, it was just taking too long of a hit to get the engine to fire up. Hopefully the 12 volt model will hang in there until I get things straight with its timing/fuel supply problems.
    Starters
    Be aware if you buy a 12 starter , you'll also have to replace the flywheel as they're different :eek: .
    if you simply take the old starter and have it rebuilt or exchanged for a 1954 pickup one , you'll be good to go .
    A question : dod you have the correct , 0 or 1 gauge battery cables ? they'll be as thick around as your thumb , anything else is going to cause problems .
    Any FLAPS can order up the correct ones , just measure what you need and go to the catalog . NAPA's Belden cables are very good .
    Also , the ground cable MUST be attached to the tranny or engine ! not the frame .
    These old starters are very simple to overhaul at home , if you can't get it working again with some cleanup and a set of new brushees , no worries , just sent it out for rebuilding then .
  9. skalywag
    skalywag Member
    Nashville
    I am using a re-built 6 volt starter (the one my truck came with from Norwood Ohio in 1953). I had a local Auto/Electric shop go thru it while they were re-winding my generator to 12 volts. Those guys were great - they even made up a battery cable using cable stock for Arc welding machines. The only issue I have experienced is sometimes the drive gear does not engage before the starter kicks in. Is there an alignment procedure I missed or shims missing?
    -Terry
  10. Wolf
    Wolf Member
    Kansas
    Paul:
    I got one from our host, one of the 1st things i did on my truck. it is a 12 V starter, and works just fine. Not sure where they get them from, but i did not have to change the flywheel. So that is nice. I can't remember how much but i thought they were around 100-150 bucks or so.
  11. vwnate1
    Pedal Starter Switch Adjustment
    The mounting holes for the switch proper , should be elongated so you can slide it a bit so the switch's contacts don't make quite so quickly .
    Mind you : a little bit of adjustment is a lot , tread softly here .
  12. skalywag
    skalywag Member
    Nashville
    Thanks Nate, I, as always, am deeply impressed with your "tribal" knowledge.
    I will take some time this weekend to make that adjustment. I don't know why I did not think of that myself (I have achieved codger status), but it makes perfect sense.
    -terry
  13. bowtiesr4me
    bowtiesr4me Member
    Evington VA. USA
    Hey Coilover,
    digya find any pics of the foot stomper installation 12v -V8yet?
    Mike
  14. Zig
    Cool!
    Sounds good to me. I'll give that a gander when I have more time. I will also pull my starter and see what happened. The switch has me wondering if it might have something to do with this.
    Thanks again all. Good ideas, good advice~ as usual. :cool:
  15. vwnate1
    I Know Nothing ~
    I just try to pay attention :) .
