need small part
Discussion in '1947-1954' started by ronaldg, Sep 26, 2010.
  1. ronaldg
    ronaldg Member
    Hi guys i am in need of a small simple part for my 1950 half ton chev. pickup i probably could make but it is ribbed so that it gripps the metal and it is behind the striker plate its a small piece of metal about 1inch long and a quater inch wide that actually slides into the body behind the striker plate the screws on the striker plate tighten into this part there are two behind each striker plate and one i have is striped so if any body has one i would be happy to pay for and pay postage I only need one My email address is cgarcia77@socal.rr.com heres a picture of it in the vice thanks for reveiwing
  2. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    What are the hole center and overall dimensions.I have a few left over that i didn't need on my 57. If they are the same your welcome to them.
    Bobby
  3. brit 50
    brit 50 Member
    Essex England, the motherland
    How desperate
    If you really can't locate any I have just cut those parts out of my truck. Be glad to send them over
  4. ronaldg
    ronaldg Member
    demensions
    Thanks bobby and brit Im not sure if the 57 would be the same but heres the demensions the best i know how 1- 3/8 long 1/4 inch thick 5/8 wide the hole is 1/4 inch in from the edge centered.
  5. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    Overall dimension of the 57 door latch shim is narrower than what your looking for.It was worth a try.Sorry
    Bobby
  6. ronaldg
    ronaldg Member
    Shims Ha
    Well thanks for taking the time bobby and checking and I learned somthing that there called shims thank you.
  7. drummin52
    drummin52 Member
    Wapwallopen, Pa
    I believe I just cut that spot out of my 52 and should still have it somewhere. I will look tomorrow for you. I'll let you know.
  8. ronaldg
    ronaldg Member
    Hi chriss
    Hi chriss its a small shim thats slides in behing the striker plate If you have one that would be great just put it in an envalope and ship it to me let me know what I owe you and ill let you know my address etc. thanks
