Rear end questions
Discussion in '1960-1966' started by cgeorgemo, Oct 30, 2002.
  1. cgeorgemo
    cgeorgemo Member
    I am revealing my ignorance here. I have a 1966 C-10 with a 12 bolt rear end. It has a 283 with a standard 3 speed transmission. Does anyone know the gear ratio that came stock in these trucks. I am going to swap the gears for something that is a little bit better for top end. I don;t really need the low end power in this truck because i have another 66 C-10 that I use for towing.
    Thanks for any help
    Brian
  2. dvalentine
    dvalentine Charter Member
    Sacramento
    It's a good bet that it is probably a 3:70 or a 4:11.
    Check the left axle tube for casting numbers. That will tell you what it came from the factory with. Or, with the rear on jackstands, turn the left rear wheel one rotation and count the number of times the drive shaft rotates. Do the math and arrive in the ball park of your ratio.
    For your 3 speed manual, I would not go any higher than 3:30.
    Dval
  3. cgeorgemo
    cgeorgemo Member
    If I get the casting numbers from the axle tube wwhere can I look up the information to find what it has in it?
  4. tkconlon
    tkconlon Member
    Steamboat Springs USA
    Hi Brian,
    You can also go to americanclassics.com and enter your VIN to find out what axle ratio was shipped from the factory.
    Tom
  5. cgeorgemo
    cgeorgemo Member
    When I went to americanclassics.com I couldn't find a vin decoder.
  6. cgeorgemo
    cgeorgemo Member
    I found it americanclassic.com thanks
  7. cgeorgemo
    cgeorgemo Member
    Alright this past weekend I put the beast up on stands and spun the rear tire one time. The driveshaft went around almost but not quite twice. According to my calculatons that is a 1.8 : 1 ratio which seems ridiculous. What is wrong with my math?
  8. zenish
    zenish Member
    stallings
    since you are not spinning both wheels,you have to double the number.that would make it 3.6 which probably is a 3.73 like most.
