Seat belts
Discussion in '1955-1959' started by bikern8, Oct 1, 2010.
  1. bikern8
    bikern8 Member
    Just installed Julianos 3 point shoulder belts....quality materials, parts for a solid and safe install even for this novice.
    Three Point Harness
    Good deal ! any chance of some pix ? especially how you welded in the upper mounts ? .
    Safety knows no season .
  3. bikern8
    bikern8 Member
  4. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Juliano's
    On my 5 window cab, I welded the back-up plates per Juliano's photo installation instuctions. They work like a charm. Make sure you get the longer latch belt, the short ones they first sent keep sliding under the seat when not in use.
    Good Link !
    Thanx .
    I hope you knew to use a BIG oversized washer underneath the floor.... he neglected to mention that part .
  6. Larrys 48
    Larrys 48 Member
    Spokane, WA
  7. babailey
    babailey Member
    Those two sites have some great information. I wish I had seen them before I purchased and installed lap belts.
    I may go ahead and install three point belts in my modified truck anyway just because these two sites make it look so easy.
    Thanks!
  8. NorCal58
    NorCal58 Member
    Carmel, CA
    Big back window
    Anybody ever use these on a big back window?
    I installed them about 6-8 years ago when I first got the truck and my dad insisted on the 3-point harness. Since I've started the restoration I have removed them and have no intention of putting them back in because I hated how they looked attached to the B pillar and could be seen through the back window.
    I'm planning on going to lap belts.
    Chris
