What do you take to fix the glasses into the frame of a vent window?
Discussion in '1947-1954' started by wokri, Nov 2, 2010.
  1. wokri
    wokri Member
    Germany
    Hello,
    I have disambled my vent windows because the windows glasses where damaged. I put the windows into a furnace and heatend them about 200 °C and pull the glasses out of the frame.
    I took a look about the frame and saw there is a black substance in the frame body. I didn't knew what kind of sbstance this is.:confused:
    So my question is, what do you take to fix new glasses into the frame?
    Wolfgang
    Glass Installation
    It's called ' Glass Setting Tape " and you can use the stuff from an old VW Kafer.....
    Heat isn't necessary , just use a dead blow mallet or rubber hammer , support the frame on a bench covered in old carpet .
  3. ol' chebby
    I have switched to quick setting urethane for my glass setting. Works well and won't pull out.
