generator with power steering pump
Discussion in '1947-1954' started by Volker, Nov 8, 2010.
  1. Volker
    Volker Member
    Germany, nearby Leipzig
    I got an information about a generator with mounted power steering pump.
    I start with my work (manual to power steering) and i think thats a great solution. only one belt an i have a perfect power steering in my truck:D
    who knows details about this part???
  2. federale
    federale Member
    Washington C.H.,Ohio
    Re:power steering
    Volker,If I remember correctly this was an option on 55-57 Chevys. Maybe the same system was used in later years too. Good luck with this project.
    John
  3. Flashlight
    Flashlight Member
    I've got one, from a 55' sedan, Ken told me not to get rid of it as its a sought after piece. But, I don't need it.
    Flashlight
    Generator
    Also used on Cadillac and Oldsmobile through 1960 or so , be sure you get a 12 volt one (red tag if the tag is still there)
  5. Kens 50 PU
  6. Volker
    Volker Member
    thats it
    exactly what i mean but i know this part with a new generator is available in the US. My problem is I don't know where is the vendor.
  7. Blueflame236
    Power steering pump
    Flashlight
    Intrested to understand the mecainicall driven hydraulic pump system even better.
    Question; Is there any electric sirquiting involved between the generator and pump or is it a plain mecanic pump driven by the main generator axle to keep up the pressure? Does the generator gets easely warn out as it has to turn an extra component ?
    Martinius.
  8. Volker
    Volker Member
    generator with steering pump
    I found it - and in Germany:D
    It's a generator from Ford with an longer axle on the rear. I use 4 screws and a clutch to connect the power pump on the generator. The generator has 70amp and the power pump deliver 100 bar pressure. Enough to work in my truck. cost in germany about 200 euro complete
  9. Flashlight
    Flashlight Member
    Martinius,
    I would defer that question to Ken, as he is actually using his. Mine was with my 235 engine and I have never really taken it apart. Volker that is nearly $300.00 for the piece, seems expensive but probably a rare part in Leipzig area. I guess by the time you shipped one from the States it would be pretty high as well. I'm glad you found one but from a Ford!! Ach du lieber, meine Gott!
    Flashlight
  10. Kens 50 PU
    I only wish I had one of those setups! Those pics were taken at the Klein Show & Shine earlier this year. It was on a really nice '55. As I understand it, the shaft on the generator is longer and it powers the pump.
  11. Flashlight
    Flashlight Member
    Thanks Ken,
    As you recall, mine is under the steps in the Barn, the thought of crawling under there was giving me a catch in my back. I do however make sure it gets the dust blown off with my leaf blower during garage sweepouts.
    Flashlight
  12. Blueflame236
    Power steering issue
    Send us some pictures from the generator Volker if you can.
    Martinius.
  13. vwnate1
    Generator Driven Power Steering
    The generator's armature has an extended rear shaft that is splined so if you center the pump correctly when you install it , the additional wear in the bushing is negligable .
    Being a generator with the power running through brushes and commutator 3" from the vented PS pump , means they wear out or loose conductivity sooner than other generators , moreso if you have a too small battery or a lot of current consumers .
    Proper care and the occasional cleaning of the commutator bars helps extend life greatly .
    If you look at Hot Rod 50's projects , this unit is often left abandoned on the original engine when it it uncerimoniously yanked and junked .
    ALWAYS talk to Hot Rodders about the unwanted original parts ! .
    FWIW , YMMV , etc. , etc. more useless trivia and yes , it is possible to get it out of a fully loaded '59 Caddy , in July , in the pump island , in the 125° F heat without taking apart anything else........
  14. Blueflame236
    Exceptional good explination!
    Thank you Nate.
    martinius.
  15. Volker
    Volker Member
    @martinius
    If i have this part in my garage i will take few pics and come back.
  16. Flashlight
    Flashlight Member
    Martinius,
    We had a nice warm day, so I went to the barn and dug out the Generator set-up. It is a 12 volt. Originally in a 55' sedan. I like the dutch and belgian women also...so healthy looking:D!
  17. vwnate1
    ' Healthy Looking ' Women
    yeah ;
    Like grammaw said : ' Ain't nabbutt a dog wants a bone ' :D .
    or , at least she might vae , had I ever met her :p .
  18. Volker
    Volker Member
    @Flashlight
    ...and the German Girls???:D
    I think i must send a pic from my wife:cool:
  19. Flashlight
    Flashlight Member
    @ Volker
    You had better keep a close eye on her:), I only missed seeing her because I could not go to Leipzig in my days in Deutschland. But...now I can:D, if the dollar ever becomes strong:( again I will return. Are cartons of Marlboro's and Americanishe Champagne still appropriate gifts for first date's?
    Flashlight
  20. vwnate1
    Volker's Wife
    So ; you got married to a Vintage Cadillac , good choice Volker ! :) .
    BTW : who's the pretty girl ? :rolleyes: .
    :D
    :p
