air cleaners
Discussion in '1947-1954' started by ccharr, Nov 24, 2010.
  1. ccharr
  2. ol' chebby
    amd expensive!
  3. ccharr
    I have seen these much higher depending on the condition.
    Holy cow !
    I havew two of these inn far better condition sitting next to my stove.....
    One came with a $3.00 Rochester carby core I only bought for the bowden cable clamp bracket...
    Who knew ? these things barely filter anything , they're crap .
    Oil bath is the way to go.....
  5. coilover
    I also have one of these outside in the weather on top an old 37 Chevy 2 dr with the original 216. I also have two that have a flat tube that runs from the carb across the valve cover to the oil bath cleaner on the other end which hangs under the flat tube. I know one came off a big truck but don't know if they are for heavy duty application or what.
  6. Guest5979
    Guest5979 Guest
    air cleaner
    You Guys can send one my way for my 52 the filter sells for 25 30 bucks.:eek:
    Dry Air Filter
    Rbert ;
    You really do need / want an oil bath one to protect your engine in this desert dust bowl we call home (So. Cal.) .
    Failing that , Po-mona or the Long Beach Swap (to-morrow !) is your freind....
  8. Guest5979
    Guest5979 Guest
    looks cool
    Yeah butt they look cool anyway.
    my 52 is a garage baby now and not a daily driver.
  9. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    I made these air cleaners out of the origonal hubcaps on my "61"...Big Tim :cool: 005.jpg
  10. ccharr
    Tim,
    Those are great, how did you fasten them to their bottom plate to cabby's?
  11. bigtimjamestown
    Jamestown Ca.
    I welded a coupler nut to the inside of the upper half then used a piece of all thread and screwed it down in to the carb. Then just spin the upper half down on to the all thread....Big Tim :cool:
  12. ccharr
    Thanks Tim,
    Those really look good sitting on top of that motor.
