My new 235 engine
Discussion in '1947-1954' started by TonyinKC, Dec 4, 2010.
  1. TonyinKC
    TonyinKC Member
    Parkville, Missouri
    Some would call this a pile of junky parts. I call it my soon to be new 235 engine. Block no. 3769716; head no. 3836848.
  2. Kens 50 PU
    Sweet! That's a late model, full pressure block and a very desirable head! Whatcha gonna do with it?:rolleyes::D
  3. TonyinKC
    TonyinKC Member
    Parkville, Missouri
    Hey Ken. I'm going to redo it and eventually drop it into my '53...I just tore it apart today---it's my $100 investment.
  4. 1952Bowtie
    1952Bowtie Member
    Spokane, WA
    Head casting numbers 3836848
    Ken, why is that?
    Thanks,
    Bob
  5. Kens 50 PU
    Bob, it's my understanding that the "848" head is a higher compression head (8.25:1) than the early version (7.5:1).
  6. Bilbo
    Bilbo Member
    Magnolia, Texas
    Can I find out what year my engine is with the block casting number?
  7. Kens 50 PU
    Hey Bill, the block casting number will get you within a range of years. For example, Tony's block number, 3769716, shows to be a 235 produced from '58 thru '62. My truck has the same block number and it was taken out of a '62 chevy panel.
    Here's a link to a good website that has a lot of reference material on casting #'s. www.inliners.org
    Ken
  8. 1952Bowtie
    1952Bowtie Member
    Spokane, WA
  9. Blueflame236
    Identification 235 Ci engine
    Need a hand to identify my engine.
    235 engine 1955 passenger car.
    Number 3835813
    Number 8836233
    0470138T-55Y
    Thanks Martinius.:)
  10. 1952Bowtie
    1952Bowtie Member
    Spokane, WA
  11. Greg_H
    Greg_H Member
    Do you know what the engine came out of? The reason I ask is that it looks to be the hydra-matic adapter plate in the background underneath the timing gear cover.
  12. Blueflame236
    Numbers identification
    Hi Bob
    No i am not shore at all. It whas in the dark i wrote down the numbers , numbers looked vage and the engine whas mighty greasy. It came of an chevrolet 1955 Belair with a powerglide tranny, but i am shore it has 136 HP.
    You may be right and i wanna thank you for your help.:)
  13. vwnate1
    235 Engine & Head
    The ' 848 ' head is not only the highest CR 235 head but it also incorporates some casting mods that make it very crack resistant .
    I'm not clear on _why_ you took it all apart , from the 'puter photo the cam looks O.K. but unless you carefully marked and remembered which lifter goes into which hole , you now need to buy a whole set of new ones as mis - matching the used lifters in their bores , will run the cam flat very quickly :( .
    Re-ground lifters are CRAP and must never be used ! EVER .
    Don't be in any hurry to bore the block or grind the crank journals...
    Rebuilding the rods of course , take the time to balance them to zero grams and you'll be well pleased with the smoothness and increase in power .
    Take lotsa pictures and keep us posted :) .
  14. TonyinKC
    TonyinKC Member
    Parkville, Missouri
    Hey Nate, The eingine was a pig in a poke. I took it apart because I wasn't sure what the guts looked like. One of the pistons was in the up position and pretty rusty. I'll have the block and head magnafluxed this week. I'll keep you posted. Here's a couple of other photos.
    Thanks.,
    Tony
  15. vwnate1
    Got It !
    I didn't realize that , good on ya for doing it right then .
    Consider using a 261 cam then as it'll pep up that 235 well .
  16. TonyinKC
    TonyinKC Member
    Parkville, Missouri
    Nate. Thanks for the idea. I'll check it out.
    Best,
    Tony
  17. Kens 50 PU
    Yo, Toneee!
    OK, I admit it! I was a slave to the "Sopranos"! Best addiction I ever had!
    We've determined that you have a late model, full pressure 235. Word of caution! You MUST put a short shaft water pump on it if you're going to put it in your truck because if you don't, you won't have enough clearance between the fan and the radiator! In addition, you'll need to make sure that you match up the fan belt width because the harmonic balancer groove is bigger on the late model 235 than it is on the older 235's and 216's. Also, remember that your rotten-chester b carb on your 216 will not fit the intake manifold on your new 235.
    Sincerely,
    Tried 'em, cussed them, figured out that they didn't work, then did it right!
    Ken
  18. TonyinKC
    TonyinKC Member
    Parkville, Missouri
    Thanks Ken. I wondered about the water pump. I see Jim Carter has the short neck pumps.
    Which carb should I be looking for?
    Best,
    Tony
    ps. I mentioned in an earlier post that I bought this truck so I could restore it with my 13 year old son Sam. Here's Sam last Saturday when he and my friend Herb helped disassemble the engine. Sam is wondering "what in the world have I gotten myself into?"
  19. ol' chebby
    I shortened the pump myself. I show it in the ssembly thread. I pressed the pulley mount down the shaft until the puley would line up with the crank pulley, then cut the rest off.
  20. Blueflame236
    Carb issue ?
    Started with the Rochester B and BC wich did`nt work that well , i overhauled both later and put them out for sale. Did the same engine swap last year and came up with an Carter YF solution for the 235 CI. Fantastic carb. with a pot stove and aut. choke .
    Beware of the fact that you have to reuse your harmonic balancer as it is important for the right cooling of your truck. Using the shortpump you might have to tweak your fanblades a bit to get anough clearance. There is`nt really not much space there.
    Good luck Martinius.
