216 235 intake engine keeper bolts
Discussion in '1947-1954' started by TonyinKC, Dec 8, 2010.
  1. TonyinKC
    TonyinKC Member
    Parkville, Missouri
    Can anyone tell me what the original finish is for the 235 intake keeper bolts? zinc? black phosphate? something else?
    Thanks.
    Tony
  2. jackson
    jackson Member
    Gold Bar, Wa.
    what are keeper bolts?
  3. Blueflame236
    Engine bolts.
    Tony
    Hardened black steel normally but i have seen them in other qualety to. The 8 qualety cold zinc bolts are to soft and i`ll recommend you not to use them where you have to tighten with a moment . You can buy complete engine sets at Jim Carter or Classic Parts or EBAY or Patricks .
    Martinius.
  4. TonyinKC
    TonyinKC Member
    Parkville, Missouri
  5. Blueflame236
    Yep these are the onces
    After you cleaned them look very carfully if there is any color differents between them , black is good , blue is not good and you can through them away. The engine heating/cooling + that they are streched by tightning them gives these bolt wear.You cannnot see it with the eyes and need to rontgen analysing them wich is fare out beond your purpose. These bolts are normally of a very good qaulity and reusable as they are.
    When tightning these bolts start in the midle of the engine and use a tightning pattern and moment wich you can find refered in your repair manual.
    You can tighten them even a bit moore after you run the engine warm and the bolts are streched ..... beware not to much ..... just a tyni bit.
