Powder Coating Running Boards
Discussion in '1947-1954' started by ronaldg, Dec 16, 2010.
  1. ronaldg
    ronaldg Member
    I was wondering if #1 any members have powder coated their running boards #2 if so does powder coating resist the gas that sometimes overflowes onto the running board.
    Answer :
    # 1 yes
    # 2 yes
    # 3 (you forgot to ask) does the modern Foo-Foo " Motor Fuel (we don't get Gasoline in Ca. anymore) stain the podwer coating or make it bubble up and wrinkle , peel etc. ? NO .
    My running boards aerw white and about 10 years old , so far so good .
  3. skalywag
    skalywag Member
    Nashville
    Ron, I had my running boards powder-coated and they have so far resisted any gasoline staining if, god forbid, there should be any spilling. They have held up very well to foot traffic as well. I just wish I had know that the powder coater was gonna blow some holes in them whilst he was bead blasting them. I could have welded and ground them out of site. :rolleyes:
    Cheers and good luck.
  4. Blueflame236
    Powder coating running boards.
    I wonder , if you sand blasted the boards and painted them with surface paint at first or whas it painted with powder coat directly on the bear steel surface ?
    Martinius.
  5. bmacdona
    bmacdona Member
    have you considered one of the color matched bed linings? It'd be resistant to chemicals, give good traction and (at least according to their claims) can be color matched to almost anything.
  6. bowtiesr4me
    bowtiesr4me Member
    Evington VA. USA
    I used black UV coated Line-X on my boards and it's great!
    I even embossed a bowtie step on each side then sprayed overtop of it. No aluminum plate rusting out my board. Just have to tell the kids it will give you a mean carpet burn!;)
    Good luck and Merry Christmas,
    Mike
