12v generator question
Discussion in '1947-1954' started by TonyinKC, Dec 18, 2010.
  1. TonyinKC
    TonyinKC Member
    Parkville, Missouri
    Guys. Since I've decided to install a mid-50's 235 engine in my '53 truck, I might as well consider upgrading to a 12v system. What 12v generator would you recommend?
    Thanks...Tony
    12 Volt Generator Answer
    Pretty much any of them , Pontiac , Oldslowmobile and Cadillacs all had higher output gennies than do the lowly Chevrolet , you needn't buy any special voltage regulator , any GM 12 volt one will do .
    I hope this helps , remember that when junkyard or swap meet hunting , the RED DELCO tags means it's a 12 volt unit.
  3. Guest5979
    Guest5979 Guest
    12v gen
    I would think a elect shop could convert your generator to 12v the same with your starter to which i would keep 6v for faster starting.
    plus i have seen it somewhere a 12v alt that looks like a generator.
    Robert
  4. ol' chebby
    Powergen makes an alternator in a generator case, but they are $$$$$$$$$$. An auto electric shop can convert your generator to 12v. I had the one in the 53 done for about $135 with full rebuild.
