changes?
Discussion in '1947-1954' started by jackson, Dec 31, 2010.
  1. jackson
    jackson Member
    Gold Bar, Wa.
    Can anybody tell me what year these trucks went from 6 volt to 12 volt? Also, what year they went from generators to alternators?
    generic answer
    If "these trucks" are small GMCs, 1955 first series and earlier were 6 volt positive ground and 1956 and later were 12 volt negative ground. '55 second series six cylinder manual transmission trucks were 6 volt positive ground while the V8 and Hydra-Matic equipped trucks were 12 volt negative ground.
    In general, 1961 GM vehicles were all generators, 1962 were a mix of generators and alternators (alternators usually on A/C equipped cars) and all alternators by 1963.
  3. Blueflame236
    Generator versus alternator.
    Bill i would like to go back using the old fashion generator again instead of the alternator! I like the outlook of the old generator much better.
    Is there any reason of not doing that ?
    Friendly regards Martinius.
  4. federale
    federale Member
    Washington C.H.,Ohio
    Re:Martinius
    Aside from much quicker charging of the battery,alternators are able to provide more power if you are running a lot of accessories. Those are the two advantages that come to mind immediately.
    John
    6 Volt Generators
    No reason why not ~
    In fact , if you take the time to hunt up a 1954 Pontiac generator and voltage regulator , it'll charge more & faster too as those old Pontiacs had power windows , radios and AC too .....
