1970 chevy brakes
Discussion in '1967-1972' started by buz1948, Mar 24, 2010.
  1. buz1948
    buz1948 Member
    Hi
    How do i remove the brake cylinder from the backing plate? It looks like a 1 1/8 nut holding it on is that it is it a left hand or right hand tread? It's on the left hand side of the truck
    Thanks buz1948
  2. sweet70beast
    sweet70beast Member
    Rexburg Idaho
    I think the stud you're talking about is the pin that the shoes push against. I believe that the brake cylinder mounts with two smaller (maybe 3/8 or 1/2) under that big nut. There is one bolt one both sides of the brake line that goes into the cylinder.
  3. drabo
    drabo Member
    Patrick AFB, Florida
    It is standard thread. Mine had a washer with locking tabs on it. Use a deep well socket and a breaker bar or an impact to get it loose. A little BP blaster might help it a little too.
