Overdrive trans
Discussion in '1955-1959' started by Dillon Hill, Feb 25, 2011.
  1. Dillon Hill
    Dillon Hill Member
    Will an overdrive unit from a 1964 chevy p/u fit in a 1959 Apache?
  2. ccharr
    Sorry about the delay in someone helping you, you might get more service asking in g the AD forum 47-55, we have all kinds of truck people there.
  3. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    what am i . chopped liver???even tho i've been known to hang out there too! lol
  4. Dillon Hill
    Dillon Hill Member
    thanks, I'll try in 47-55. That is unless Bobby57 can shed some light on me
  5. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    yes you can. a good schematic will help with the install.
  6. Dillon Hill
    Dillon Hill Member
    and where might one find such a schematic?
  7. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    the one person that i can think of on this forum is Bill Hanlin he seems to be very savvy on technical resources. you may want to be in touch with him
    Bobby
  8. Bill Hanlon
    GMCs (my speciality) didn't use the BW overdrive, so I'm afraid I don't hane any info about them.
  9. Dillon Hill
    Dillon Hill Member
    A schematic would be for the electrical hook up if i'm not mistaken, so if I were to use a manual control for the O.D. I should be in the clear.(?) My other concern is whether the shift linkage from the colum shifter will hook up or will I need to retro fit
  10. Dillon Hill
    Dillon Hill Member
    coilover seems to have set me at ease with his response in 47-55. Any other thoughts would be greatly apprieciated
  11. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    if its a 3 speed it will work fine.you will have to adjust the linkage a little but it should be fine.
  12. dan cocomise
    dan cocomise Member
    Looking for More Top end
    whant more top end out of 1948 1/2 ton.if i step up the rearend my 3 speed is to high in first gear.could i use t5 trans 5 speed and still use my torquetub rearend.or could i use a newer gm 1/2 ton drivetrain use whith adapter kit from classicparts.
  13. trucktony
    trucktony Member
    The Netherlands
    For your information on the earlier BW overdrive:
    http://www.classictruckshop.com/clubs/earlyburbs/projects/over/drive.htm
    there is an quit easy layout of the electrical wiring of the overdrive
    I just made a on/off on the relay with an indicatorlight on the dash and take my foot from the gaspedal to let it slide in to overdrive.
    Only thing is you cannot put it in reverse when the light/overdrive is on.
    normaly that is taken care of by the govenor that takes in/out at around 28mph
    so if you want to drive in overdrive without the hassle just put some spark on the relay take your foot from the gas and there she goes.
    You will have to get some "feel"to it but I can tell you it's great to drive
    you will do 62mph at 2000rpm on 225/75/15 tires with a 3.90-1 gear ratio in overdrive.
    That will save you some fuel and you will keep on speaking terms(noise) with your wife along the way :rolleyes:
    have a good one
