clutch springs grinde against flywheele bolts
Discussion in '1947-1954' started by dan cocomise, Mar 9, 2011.
  1. dan cocomise
    dan cocomise Member
    had drivetrain nois when letting out clutch,then whent away.pulled engie to rebuild.noticed sprigs on clutch where grinding into flywheel bolts.i think the bolts where the right low profile heads.there was very little head to grab but they came out.whant to put trans back whith rebuilt engin.is flywheel wheel woren.i whant to change the trans and drivetrain in months to come.aney ideas thanks
  2. coilover
    A clutch plate won't work if it's in backward so something is moving the plate and springs towards the bolt heads. Could the plate be wrong and have springs that are too large in diameter? I guess it's possible for a flywheel to be resurfaced enough times to move the plate closer but I've seen one that the entire lining has come off the plate and don't recall them hitting the bolt heads (although they didn't go far without the lining on). When you get a new plate put some Play Dough on the head of each bolt, bolt everything up, then take back apart and see how much clearence you have by measuring the thinnest parts of the now mashed to fit Play Dough.
  3. Chiro
    Evan!!!
    Brilliant!!!
