Fuel Filler
Discussion in '1955-1959' started by 58fleetside, Mar 15, 2011.
  1. 58fleetside
    58fleetside Member
    Boulder, CO
    I spent a good part of Saturday trying to get my fuel filler assembly through the rubber grommet. Any hints? I tried putting the tube through the grommet then into the cab. I tried putting the grommet in then forcing the tube through it. There must be a trick I am missing. At least I hope there is...
    Thanks in advance.
    It's A BEE-Atch !
    I insert the grommet then spray it with aerosol silicone then wiggle the filler neck right into place , easy as pie .
  3. babailey
    babailey Member
    Not sure "easy as pie" is correct but I have used the method vwnate1 suggested.
  4. 58fleetside
    58fleetside Member
    Boulder, CO
    Thanks guys! That worked great.
