Hello, I need your help again, where do I get the seal sitting in the housing on the differential gear where the propeller shaft goes in? (see photos) The differential gear leaks very strong out of the input of the propeller shaft. So I opened it and all the both seal were bad. These two seals have metall cage. The cage have a outside diameter of 88,35mm Can someone tell me where do I can buy those seals or is there a alternative option which I can put in the housing? Ask Wolfgang
Seals hi worki when i changed rearends this paricular seal came with the kit that i got from patricks in arizona along with a bunch of other parts try calling them i know they have or can get it if i remenber correctly it was made of almost like leather it was a real tough material any way heres the linkmailto: patstrks@aol.com
Patricks is a very good recommendation. Wolfgang i bought a lot of parts from Patricks and all parts fits perfect. Write or call Danese, she can help everytime.
