Ground strap
Discussion in '1947-1954' started by denisf, May 28, 2011.
  1. denisf
    denisf Member
    Colchester, CT/ Clermont, FL
    OK my 52 had ground to frame from batter, red cable, black power line to starter, and a braided ground from frame to engine.
    The braided strap went under the spring return for the floor starter.
    How should I do this for my 12 volt system?
  2. rgmj00
    rgmj00 Member
    Hot Ass Bakersfield
    Same. Ground block to frame, frame to battery. Are you removing the foot starter?
  3. denisf
    denisf Member
    ground
    Thanks not removing foot starter.
    Wrong !
    Just run the ground cable to the tranny or engine , retaining all the other ground straps as they're for good lighting and accurate fuel gauge .
    6 or 12 volts , even the uncommon 24 volt system , the ground cable *must* ALWAYS be connected to the engine or transmission ! .
    NO exceptions ! :p .
    Just because a shoddy job works , doesn't make it right .
  5. spika
    spika Member
    Central Montana
    As the original system had red (positive) to ground, are you all suggesting he keep it positive ground? I believe I would recommend going to the commonly accepted negative ground, and make that black cable from battery to frame and engine, with box and cab bonded to the frame with a braided cable as well. Just the way I would do it...
  6. ol' chebby
    Check the polarity of the cables, not just going by colors.....Ground straps are your friends! The more things are grounded, the more efficiently they operate.
  7. rgmj00
    rgmj00 Member
    Hot Ass Bakersfield
    Yeah that was my understanding. My trucks have had a ground coming from the frame to the negative on the battery terminal. As well as the braided cable from the block to frame.
    Negative Ground
    Is the way to go , just be sure if it's an original 6 volt system , to reverse the leads in the ignition coil and yes , they're reversed in a positive ground system .
