Chassie ?
Discussion in '1960-1966' started by bigk1220, Aug 30, 2003.
  1. bigk1220
    bigk1220 Member
    I have a 66 Chevy C10 pick up and there are two support beams located at the rear end. They are mounted on the rear end and going to the frame. I was wondering what the Real name of these support beams are called and where I can get them. Thanks
  2. zenish
    zenish Member
    stallings
    control arms.if chevyduty doesn't have them www.imctruck.com has them for 250 apiece.i would try to find used ones in a 65-72.also someone makes reinforcement weld on panels for them too.you should check the forum at www.chevytalk.com
