1955 Gas tank under the Bed Conversion
Discussion in '1955-1959' started by akeane01, Nov 10, 2010.
  1. akeane01
    akeane01 Member
    I have a C3100 1955 1st series and recently took out the gas tank with lots of inside rust and pin holes. I thought about replacing it but I really dont like the idea of having the tank in the Cab.I have seen some other conversions on different vehicles but not on this type of truck. Has anyone got pictures/options on what they did to reliably convert the tank?
    thanks for the help..
  2. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    I did this conversion to my 57.I hope the pics help.
    Bobby
    Underbed Fuel Tank
    IIRC ;
    The Econoline vans have a nifty tank that fits right between the frame rails and actually has a filler you can use....
  4. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    This maybe a little extream but this is what I did on my 54....Big Tim :cool: tims pics 029.jpg
  5. bowtiesr4me
    bowtiesr4me Member
    Evington VA. USA
    This may not be the cheepest but on my '48 they come with side mount between the frame rail tank.The aftermkt. now has them for around $400. straps, fill hose, sender unit,all look original and you fill from the same side, just thru the bed not the cab. I think our host carries them also.
    Good luck
  6. coilover
    This is a 48 likes Mike's that shows the factory mounting. The rear has been changed to an open driveshaft so it is very much like a 55 1st series. For $50 worth of material and common home tools you can make your own tank. The only outsource would be the welding. It's just a metal box with a fuel outlet, filler tube, and a sending unit hole. I think I posted build pics on the AD Forum.
  7. Lakeroadster
    Lakeroadster Member
    Central Colorado
  8. RobY56
    RobY56 Member
    San Diego, CA
    Bobby did use install an electric fuel pump to get the gas forward?
  9. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    No I didn't.Just used the stock pump that came with the crate motor through a 3/8 fuel line and a fram fuel filter with no problems.
    Hope this helps.
    Bobby
  10. drivea55
    drivea55 Member
    Houston, Texas
    If you're worried about the danger of the tank in the cab, don't. If the cab is crushed enough to rupture the tank, why would you care? You're probably already a goner. I grew up with tanks like this in the 60's and early 70's. There no big deal and you'd be keeping with original.
  11. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    I wasn't worried about that. I wanted the extra weight over the rear wheels.Getting the gas tank out of the cab made room for the center console and storage behind the seats.
    Bobby
