Radiator Cap P/N ? (0 # )
Discussion in '1947-1954' started by vwnate1, Jul 10, 2011.
  1. vwnate1
    I'm not finding the Stant or whomever non pressure radiator cap part number , anyone here know what it is ? .
    As soon as I ge the Stant / Delco / Napa / whatever part # , I'll order one up to - morrow morning for a project I'm working on .
    TIA ,
  2. federale
    federale Member
    Washington C.H.,Ohio
    Re:0 Pounds
    Nate what would be the purpose of a 0 pounds radiator cap? Isn't pressurizing the system to raise the boiling point the whole idea behind it?
  3. steve
    steve Member
    Virginia
  4. Kens 50 PU
    Nate, if you have an O'Reilly's flaps near you, have them order you a Murray Ultra radiator cap p/n 7003. I picked one up for my truck a couple of years ago. Took a day to get it from the central warehouse and cost $6.99.
    Thanx !
    Yes , having pressure raises the boiling point of plain water 3° for each pound of pressure but this is for a non truck special project .
    Once you've added 4 # and a 60/40 % Coolant to Distilled Water mix , boiling is pretty much not going to happen unless things get really out of hand .
    This project is on an older junk that doesn't overheat no matter what but is crispy & dribbles coolant so I'm wanting to try a non pressure cap .
    I was hoping for a Stant etc. P/N , I'll give ORielly's a go .
  6. Keystoner
    Keystoner Member
    Pennsylvania
    THAT's IT !
    I already have one on order from my regular supplier thanx to the P/N's previously posted but this is good to know .
    Oddly , I couldn't find it in the Stant OnLine Catalog ......
    I've now missed two days of work because of my injuries dangit :mad: .
    I'd like to once again say THANK YOU ALL (note clever use of CHEVROLET BLUE there) as every time I need help , I just ask and you're there for me ~ I could never repay all the good help I've gotten over the years here .
  8. skalywag
    skalywag Member
    Nashville
    Nate, Our sponser has: Product : 78-405 Price : $4.95 in their catalog.
    I have been running one on my 235 for several years and all is good so far. I will not make the mistake of pressurizing my coolant system after having to re-build my heater core. I have a 3 row radiator and a std 180 degree F thermostat and it stays just below 180 (even in a Nashville summer).
    Take care,
    Terry
  9. DeadZoneTruckin
    DeadZoneTruckin Member
    The original caps were zero pressure.
    As long as you do not exceed a 4 lb. cap you will have no worries of blowing up the original radiator or heater core.
    The AC RC-4 is what we use.
